Flexible filament failed to print
b.ilya
(@b-ilya)
I am using Ninjaflex on MINI+, prints were fine, every other material printed excellent (PLA, ASA, Nilon, Flex), in the last couple of tries the extruder failed to push the Ninjaflex filament.  The filament is getting pushed out between the bowden tube and the filament spur. That problem never happened before and i can't solve it.
I Checked for clogging, tried different materials - prints were good.
DID A COLD PULL
Cleaned the spur gear.
*My observation: The problem is getting worse, at first the problem started after 3 layers, now its happening at purging
Opublikowany : 15/03/2022 9:17 pm
