Firmware update gone wrong, stuck on looking for bbf
[Resuelto] Firmware update gone wrong, stuck on looking for bbf
Ofiros
(@ofiros)
I've updated my Prusa Mini Firmware to 6.1.4, but after performing the flash and reset it get stuck on 'looking for bbf' screen and never get over it,
I've tried changing the USB, reseting with or without it, removing the BBF file already on it and reset hoping it would help.
I even gone further and updated to 6.2.0 Alpha hoping a new flashed version will fix it - but it didn't, the issue persists.
Please help me get this printer back to a functioning mode.
Respondido : 08/11/2024 7:04 am
Ofiros
(@ofiros)
RE: Firmware update gone wrong, stuck on looking for bbf
Sorry to be the one answering his own question.
as it seems the problem was the USB extension core, once I've connected the same usb to the printer itself (and not through the very useful day to day extension) the installation completed successfully!
Respondido : 08/11/2024 7:20 am
2 les gusta
Bunch8
(@bunch8)
Miembro
I also had a USB extension so I tried plugging my Samsung USB flash drive directly into the USB on the Mini but it still didn't work.
I tried a generic no-name USB drive and that worked.
It seems the Prusa Mini is very sensitive to the brand of USB drive used.
Respondido : 13/12/2024 7:59 pm
verse
(@verse)
Miembro
I just came across this problem. After retrying for about 20 times, i moved all the stl files to a folder "old" and the update worked immediately. It feels like the printer didn't look past the first x number of files in the root directory of the usb drive.
Respondido : 07/06/2025 7:50 am
2 les gusta
Remco
(@remco-2)
Miembro
Thank you!  That did the trick for me.
Respondido : 29/11/2025 4:03 pm
1 les gusta
npanth
(@npanth)
Miembro
I had this issue when trying to update a Core One from bootloader 2.4 to 2.5 and the firmware from 6.2.0 to 6.4.0.  I tried reformatting the thumb drive as fat32 and making the partition smaller. Eventually, I tried an old 4gb thumb drive I had lying around, and it was able to update the bootloader and firmware.
Respondido : 23/12/2025 9:23 pm
1 les gusta
