Filament stuck-not loading or unloading
Hi. I have Prusa MINI, and I would like to ask what to do if my filament is stuck and it does not load or unload. I looked through all the inspection doors, but nowhere did I see the filament stuck. It's probably stuck somewhere in the extruder. Could you please advise me what I should do?
This topic was modified 4 years temu 2 times by Friv
Opublikowany : 05/05/2022 3:17 pm
RE: Filament stuck-not loading or unloading
I'd start with removing the bowden tube and see if the extruder will move filament without the hotend in the equation. If no, then it may be time to disassemble the extruder. If yes, then I would look at a clog in the hotend.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Opublikowany : 06/05/2022 1:22 pm
