Filament Sensor small PTFE tube came out.. how to return it? (Prusa MINI+)
rbid
 rbid
(@rbid)
In the morning when unloading a filament (that had a small 'clog' in its end) , the small PTFE tube on the filament sensor came out. (2cm PTFE tube)
  1. How to insert it back to the sensor? (I guess it serves as a filament guide)
  2. If pressing the small tube in the orifice is enough, how deep to insert it?
Thanks in advance.
Publié : 19/10/2022 6:30 am
René
(@rene-3)
At my sensor,
can the tube 4.6 mm to be pushed in.
Do not do this using pliers,
but with a piece of sand paper
that you wrap around the tube in such
a way to have more grip on the tube.
Publié : 19/10/2022 8:42 am
Membre
RE: Filament Sensor small PTFE tube came out.. how to return it? (Prusa MINI+)
Just press it in gently.  I have removed it from most of mine.  It has not changed its performance for me.
Posted by: @rbid
Thanks in advance.
Publié : 19/10/2022 8:45 am
2 personnes ont aimé
Michael Musgrove
(@michael-musgrove)
I've had the tubes come out so many times, I have about altogether just forgotten about the filament sensor. It's been more trouble than it's worth for me. (Same with the satin sheet I bought. I've used it twice and the trouble hasn't been worth it. The Satin sheets are 1/2 the thickness of the steel sheet so everything has to be set up for that sheet as well, and I see no major differences to keep swapping them out for no reason. Others may have a different experience, but that's been mine)
Michael B. Musgrove
Publié : 21/10/2022 1:27 am
HTRWBR
(@htrwbr)
Membre
The sandpaper around the PTFE tube to insert it into the sensor was the piece I was missing, great idea. I replaced my tube with a longer one, but all PTFE tubes I try are bigger than the hole. This helped alot. Thank you, Rene.
Ce message a été modifié il y a 11 months par HTRWBR
Publié : 13/06/2025 5:10 pm
