Filament not loading - gets stuck
After loading\unloading many spools of filament. Now, when I try to load the filament, it loads into the Extruder Drive Gear but doesn't go past that point.
I cleaned the Extruder Pulley according to the directions. But, after I reassembled it it did the same thing.
Every time I eject the filament, it seems to have a bite mark out of it from the gears trying to feed it through.
I've tried a few adjustments to the idler screw, but that hasn't changed anything either.
Any help would be appreciated!
This topic was modified 2 years ago by mbone3000
Posted : 02/06/2023 10:33 pm
