[Solved] Filament not loading - gets stuck
mbone3000
(@mbone3000)
After loading\unloading many spools of filament. Now, when I try to load the filament, it loads into the Extruder Drive Gear but doesn't go past that point.
I cleaned the Extruder Pulley according to the directions. But, after I reassembled it it did the same thing.
Every time I eject the filament, it seems to have a bite mark out of it from the gears trying to feed it through.
I've tried a few adjustments to the idler screw, but that hasn't changed anything either.
Any help would be appreciated!
This topic was modified před 3 years by mbone3000
Napsal : 02/06/2023 10:33 pm
mbone3000
(@mbone3000)
RE: Filament not loading - gets stuck
The short tube inside the Bowen Tube was clogged, the problem was solved by disassembling the parts a bit more.
Napsal : 03/06/2023 3:46 am
