Filament does not come out of the nozzle any more
Greetings!
I am using a Prusa Mini+, filament is high speed PLA, diameter: 1,75 mm, nozzle: 0,4 mm
and after yesterdays filament change, nothing comes out of the nozzle any more.
I have tried to repeat the filament change a couple of times, stuck the needle fully into the nozzle, took the nozzle out and tried the filament change without the nozzle, that worked. Place the nozzle and tried again, nooo!
What do I need to do?
Opublikowany : 16/05/2026 4:33 pm
https://help.prusa3d.com/article/clogged-nozzle-hotend-mini-mini_112011
https://help.prusa3d.com/article/cold-pull-mini_126399
Opublikowany : 16/05/2026 6:15 pm
