Faulty mini
NNHDesign
(@nnhdesign)
Faulty mini
Hi there everyone
My mini has been running perfect for almost 1/2 year now but Now it keeps rebooting after a very short while printing..?
Does anybody else have the same problem and do you have a solution..?
Best regards
Nicki Holm
Denmark
Faulty Mini
This topic was modified 4 years ago by NNHDesign
Posted : 04/04/2022 8:05 am
Kalimero
(@kalimero)
RE: Faulty mini
The printer restarts when the system board supply voltage drops. Or in case of a program error (watchdog). It can be a faulty wiring, a faulty power supply, or a faulty firmware.
Nejsem zaměstnancem Prusa Research.
Posted : 04/04/2022 4:07 pm
NNHDesign
(@nnhdesign)
RE: Faulty mini
It doesn't Come with any massage on the screen. I've chatted with the prusa support and followed their instruktions and they say that there are no loose wires 🤔
Posted : 04/04/2022 7:06 pm
Kalimero
(@kalimero)
RE: Faulty mini
I mean the power lines to the printer. The voltage may fluctuate.
Nothing can be displayed on the screen during restart.
I recommend measuring the 24V supply voltage with a memory oscilloscope.
Posted : 04/04/2022 7:17 pm
Kalimero
(@kalimero)
RE: Faulty mini
Restarting the printer can be caused by:
1. button, it can be excluded
2. firmware error, can be reloaded
3. by a drop in the supply voltage
4. motherboard failure
Posted : 04/04/2022 7:30 pm
NNHDesign
(@nnhdesign)
RE: Faulty mini
The funny thing is that it will print some files but others just reboots it..?
I've tried the same files on my ender 3 and there it works ? 🤔
Posted : 05/04/2022 8:29 am
Kalimero
(@kalimero)
RE: Faulty mini
That is understandable. Another printer may not have the same problem.
Posted : 06/04/2022 6:11 pm
3DK
 3DK
(@3dk)
RE: Faulty mini
Have you tried a different USB memory stick?
Posted : 06/04/2022 7:13 pm
EinTiroler
(@eintiroler)
RE: Faulty mini
I have been experiencing the same problem for three days. I thought I reset the Mini to factory settings and since then the wizard also comes after switching on and aborts with a reboot.
If I do not run the wizard, then I can not print. At print start or when changing filament the printer crashes.
Wiring looks good.
If I heat the nozzle with the heat bed, then I can print.
I have updated firmware - without success.
Posted : 06/04/2022 9:30 pm
Kalimero
(@kalimero)
RE: Faulty mini
Probably a motherboard failure. Contact support.
Posted : 07/04/2022 6:31 am
Zoltan
(@zoltan)
Member Moderator
RE: Faulty mini
Hi @nnhdesign,
could you please extend your info according to this link structure? We want to help you, you have to tell us ... – https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/we-want-to-help-you-you-have-to-tell-us/
Posted : 11/04/2022 9:03 am
NNHDesign
(@nnhdesign)
RE: Faulty mini
Doesn't help and like i wrote above this i can print litho on it but nothing Else right now 🙁
Posted : 11/04/2022 11:21 am
NNHDesign
(@nnhdesign)
RE: Faulty mini
I have chatted with the prusa chat for 2 1/2 hours and tried everything they told me and still problems 🙁
Posted : 11/04/2022 11:22 am
Zoltan
(@zoltan)
Member Moderator
RE: Faulty mini
If you do not provide detailes, nobody will be able to help you.
Posted : 12/04/2022 4:57 pm
Zoltan
(@zoltan)
Member Moderator
RE: Faulty mini
Can you attach the gcode file which makes your mini crashing?
Posted : 12/04/2022 4:58 pm
NNHDesign
(@nnhdesign)
RE: Faulty mini
It's everything i print beside litho prints that makes it reboot 🙁  can't tell anymore than what the video in the top of this shows
Posted : 12/04/2022 6:43 pm
jcadcell
(@jcadcell)
RE: Faulty mini
I second the suggestion by @3dk to try a different USB flash thumb drive. I have been having gcode corrupted on the stick supplied with the printer which causes the printer to do strange things, including restart the bed leveling in the middle of a print. Plus, it's really easy to try this one - no oscilloscope needed.
Posted : 28/04/2022 1:19 am
Zoltan
(@zoltan)
Member Moderator
@nnhdesign
1. Did you slice and positioned the stl file with PrusaSlicer and set for MINI - I suspect not, because printing the circle appeares not centred to the sheet?
2. Or did you print directly from gcode file you downloaded?
3. Does it fail all the time or only for specific .gcode files?
4. You did not provide any .stl nor gcode file to verify, the files are good for other MINI printer.
Posted : 28/04/2022 6:37 am
