Extra thick overflowing layers at the same spot every time
randomt3chgirl
(@randomt3chgirl)
bad looking benchyAll of my prints on my new MINI+ Kit have come out with this ugly line at this specific layer height. I have tried different filaments, different GCODES, everything. I recently was given advice to check my belts, and while I did notice they were not perfect, fixing them didn't help. What should I do?
Opublikowany : 25/01/2022 5:49 pm
randomt3chgirl
(@randomt3chgirl)
RE: Extra thick overflowing layers at the same spot every time
Latest Firmware and PrusaSlicer versions, btw.
Opublikowany : 25/01/2022 5:50 pm
Michaël Fortin
(@michael-fortin)
I've had something like this happen before and the issue was a partial clog. No idea why it always occurred at the same height (much lower, in my case).
You could try doing some cold pulls. If cold pulls aren't enough, you might try one or two with the hotend PTFE tube removed, which could get rid or more gunk if there is any between the hot end PTFE and the bottom of the heatbreak. Also check your hotend PTFE tube to make sure it's the proper length.
How many prints did you make before this started occurring?
Opublikowany : 27/01/2022 5:07 am
