[Gelöst] Clogging midprint stops extrusion
TeachingTheDetails
(@teachingthedetails)
Hello,
I realize, this is a common issue, but I still haven't been able to solve it.
The Mini clogs midprint into any longer print after an hour or so. A benchy is about as long as it can print without clogging.
Overheating to 250°C causes material to leak out and printing works as usual afterwards. Except it will clog again after some time.
I am printing PLA at 215°C directly from a drybox positioned above the printers. A Cr-10s with Hemera extruder prints the same filament from the same drybox without problem.
Steps taken:
removed filament sensor and disabled it in menu to reduce mechanical drag on filament
removed clog by heating to 250° and pushing the acupunctureneedle many times into the nozzle
inspected the extruder gears for filament residue (there was some from the chewed through filament which I removed)
Best Answer by TeachingTheDetails:
Sorry.
User error. I had grabbed a role of PLA+, not PLA. Further increasing the hotend temp to 225°C leads to solid prints.
hw: PRUSA MINI+, FW 4.3.3 & Cr-10s w/ BLTouch, Ezboard, Hemerasw: PrusaSlicer 2.4, Windows 11
Veröffentlicht : 19/11/2020 10:10 pm
remotelove
(@remotelove)
RE: Clogging midprint stops extrusion
You have to clean the extruder gears mor. The stock extruder is not very tolerant of deviation.
Veröffentlicht : 20/11/2020 9:47 am
remotelove
(@remotelove)
Also, absolutely do not raise temps in this condition. PLA is happy around 200C.
Pics of your heatblock and heatbreak are welcomed.
Veröffentlicht : 20/11/2020 9:50 am
TeachingTheDetails
Sorry.
Veröffentlicht : 20/11/2020 5:15 pm
remotelove
(@remotelove)
Cool. My Sunlu PLA+ requires much higher temps just to get decent bed adhesion, so that makes complete sense.
Veröffentlicht : 20/11/2020 7:38 pm
