Can't unload filament mid-print w/IR sensor
Incognito99
(@incognito99)
Hello,
I'm trying to print a 2/C object using different Prusament filaments, but the initial filament will not unload. If I resume printing, it will continue printing fine with the first color, which I'm assuming means no clog. The PTFE tube seems to be clear, but it's less obvious around the IR sensor.
Unloading filament happens normally when the Mini+ is at idle and no prints are queued.
Thanks.
Publié : 10/08/2021 7:02 pm
Membre
IR Sensore
Why do you have an IR sensor on the mini?
Publié : 10/08/2021 9:35 pm
Incognito99
(@incognito99)
Filament sensor
It’s an option:
https://shop.prusa3d.com/en/minimini/1016-filament-sensor-mini-assembly.html
Thanks.
Publié : 11/08/2021 1:39 pm
Membre
Sensors
Posted by: @incognito99
It’s an option:
Thanks.
I apologize.  I was confused.  I took mine apart and realized what the sensor is.  I have two other types of sensors.
Publié : 11/08/2021 7:56 pm
