Can't load filament
mr printsley
(@mr-printsley)
Can't load filament
Can't get the extruder to grab the filament. I can push it all the way down the tube into the extruder, but when I hit load, it never grabs. Before I unloaded the last filament, it was printing fine however.
Thanks for any help.
Posted : 09/05/2020 7:02 pm
tammets
(@tammets)
RE: Can't load filament
https://help.prusa3d.com/en/article/clicking-extruder-under-extrusion-and-clogging-mini_112011#there-are-3-main-things-to-check-in-case-of-the-extruder-clicking-or-under-extrusion-on-the-mini
Check the tension of the idler on the springed-screw.
Posted : 13/05/2020 9:31 am
Matteo Cristini
(@matteo-cristini)
Posted by: @priit-t
I second this. I had a similar issue and adjusting the idler tension fixed it.
Posted : 18/05/2020 2:33 pm
