[Rozwiązany] Blocked Extruder Around Heatsink
Will
 Will
(@will-4)
Hi everyone,
I am struggling to unblock my extruder.
I have removed the ptfe tube (which was clean) and the nozzle (also clean) so my problem is somewhere in the heat sink.
I am unsure how to unblock this part. I have tried shoving allan keys down while hot, using the needle.
Any suggestions much appreciated.
Thanks, Will
Best Answer by mark:
Posted by: @will-4
Hi everyone,
Thanks, Will
I expect you will have to rebuild the hot end. You probably have leaked filament stuck in it.
https://help.prusa3d.com/en/guide/how-to-replace-a-heaterblock-heatbreak-mini-mini_122769/
https://help.prusa3d.com/en/guide/how-to-replace-a-hotend-ptfe-tube-mini-mini_119449
The help site has many other pages to describe various maintenance issues.
The PTFE tube can shrink and leak filament where is should not go. You probably should replace it or you will be back to where you are now.
Regards,
Mark
Opublikowany : 15/01/2022 1:37 pm
mark
 mark
(@mark)
RE: Blocked Extruder Around Heatsink
Posted by: @will-4
Hi everyone,
Thanks, Will
Regards,
Mark
Opublikowany : 15/01/2022 4:12 pm
1 ludzie polubili
Will
 Will
(@will-4)
Awesome response Mark, thanks a lot!
I took it apart and some PLA was jammed in heat break.
Printing beautifully once again 🙂
Will
Opublikowany : 15/01/2022 6:20 pm
