Bed leveling not working
Hi there,
This is my bed visualizer. Every spots seem good enough
However, first layer calibration failed. The left side always be lower than right side
It not makes sense. Before the first layer calibration, the process Mesh Bed Leveling works great (every spots can be seen on the bed visualizer)
I also check the nozzle height from monitor when printing, the height difference around 0.1 mm from left side to right side. According to the bed visualizer, the height difference should be less than 0.03 mm. They are not synchronized?
Can someone give me a hint to solve this issue?
Thanks in advance.
My printer is Mini not Mini+.
Bed visualizer data is from Pronterface.
My heatbed uses springs to adjust height instead of original spacers.
Questa discussione è stata modificata 5 years fa 2 tempo da Dylan210
Postato : 11/03/2021 8:38 am
