1 time ~2mm y-axis shift after 1 or two layers
JRB
 JRB
(@jrb)
Membre
My prints have no shift at all, except, when printing helical gears (not spur gears, for some reason), if the gears are clustered near the center of the build plate, I get a layer shift after 1 or 2 layers. After that, all is fine. If I rerun the gears but spread them out on the build plate, all is fine. So, very specific, but strangely repeatable with several different helical gear designs - helical and double helical internal and external gears (for a planetary gear). interested in any thoughts regarding this, even though I have the workaround of spreading the objects out... - Thanks!
Ce sujet a été modifié il y a 1 year par JRB
Publié : 03/03/2025 11:31 pm
_KaszpiR_
(@_kaszpir_)
RE: 1 time ~2mm y-axis shift after 1 or two layers
Check your y axis belt tensions.
Publié : 04/03/2025 8:36 am
