1 time ~2mm y-axis shift after 1 or two layers
JRB
 JRB
(@jrb)
My prints have no shift at all, except, when printing helical gears (not spur gears, for some reason), if the gears are clustered near the center of the build plate, I get a layer shift after 1 or 2 layers. After that, all is fine. If I rerun the gears but spread them out on the build plate, all is fine. So, very specific, but strangely repeatable with several different helical gear designs - helical and double helical internal and external gears (for a planetary gear). interested in any thoughts regarding this, even though I have the workaround of spreading the objects out... - Thanks!
This topic was modified před 1 year by JRB
Napsal : 03/03/2025 11:31 pm
_KaszpiR_
(@_kaszpir_)
RE: 1 time ~2mm y-axis shift after 1 or two layers
Check your y axis belt tensions.
Napsal : 04/03/2025 8:36 am
