Any way to convert an "ABS" gcode into "PLA" ?
Chakotay
(@chakotay)
Help! I have an old .gcode file that was created in Slic3r for use with ABS on my Prusa Mk2.5.
However, I don't use ABS anymore, but I also don't have the original .stl file anymore (i.e, I can't simply re-export with PLA settings.)
Is there any way to covert this .gcode file to print with PLA?
Thanks.
Napsal : 12/02/2022 12:18 am
Lichtjaeger
(@lichtjaeger)
RE: Any way to convert an "ABS" gcode into "PLA" ?
You can try to replace the temperature commands in the start g-code with PLA temperatures, but it will never be as good as reslicing the model.
The difference between two materials includes extrusion factors, temperatures, speeds and cooling settings. Those settings do influence each line of the gcode. So you can't change some lines and expect to get the same results as from a freshly sliced file.
PLA can handle ABS speeds, but especially the cooling is handled very differently between those materials.
Napsal : 12/02/2022 8:25 am
JustMe3D
(@justme3d)
Alternatively print it in ASA, which is much easier to print than ABS, and change the heat settings in the main menu once the print starts. Might be worth a try.
Napsal : 12/02/2022 9:11 am
danielkrah
(@danielkrah)
When you print it in PETG it is close enough.
Just lower the printing temperature to 230°C and the bed to 85°C and set the fan to 60%
... and do it again after the 1st layer.
Napsal : 13/02/2022 2:53 am
