Thermal Runaway/Print Fan orientation
lutgendorff.film
(@lutgendorff-film)
When I try to run a print the printer lays down the first layer then goes into Thermal Runaway mode.
I was doing some maintenance on my Mini which resulted in the hot end resting at a lower position, I believe because of the new PTEF tube feeding it. Because of this, I believe the print fan is now blowing onto the heat block and causing the issue. Is there a way to lower the fan so that it doesn't blow on the heat block, or should I be trimming the PTEF tube so my hot end can rest higher? Picture attached to determine if the fan is positioned correctly or not.
I have also checked for damaged wires and have not found any. The printer will maintain a temp of 215 when I set the nozzle temp. The problem only occurs during printing.
Opublikowany : 13/02/2022 2:49 am
lutgendorff.film
(@lutgendorff-film)
RE: Thermal Runaway/Print Fan orientation
Something else I just thought of, if I had the hotend heatbreak out of the heat sink could I have messed up the thermal paste and would replacing that be a potential solution?
TIA
Opublikowany : 13/02/2022 3:09 pm
mark
 mark
(@mark)
Posted by: @lutgendorff-film
TIA
Did you add new thermal paste? I am not sure old stuff will work as it may have dried out and won't fill the gaps like new stuff does. Follow Prusa's instructions for replacing the heatbreak:
https://help.prusa3d.com/en/guide/how-to-replace-a-heaterblock-heatbreak-mini-mini_122769/
Regards,
Mark
Opublikowany : 13/02/2022 3:36 pm
