[Gelöst] Printing problems as Z increases
NarlyB
(@narlyb)
As my Z increases I get the print issue as seen in the attached photo.
I'm printing on a Mini with a 0.6 nozzle, Bondetech extruder and heat break upgrades.
This happens on only two sides of this print.  The other two sides look perfect.
Could this be a frame alignment issue?
Best Answer by Nikolai:
Looks to me like over extrusion. Check your slicer settings, maybe you missed something for the 0.6 nozzle configuration.
Dieses Thema wurde geändert Vor 6 years von NarlyB
Veröffentlicht : 27/09/2020 5:59 pm
Mitglied
RE: Printing problems as Z increases
Is this the only item on the plate?
Veröffentlicht : 29/09/2020 4:15 pm
NarlyB
(@narlyb)
@charles-h13
This is the only object on the plate.
Veröffentlicht : 29/09/2020 10:17 pm
Mitglied
Have you tried a different filament?  This could be a number of things to include hydrated filament.  It could also be an extrusion issue.
Veröffentlicht : 29/09/2020 10:19 pm
NarlyB
(@narlyb)
@charles-h13
I was printing with Prusament PLA Army Green.
I will try a different filament.
I will post the results once done
Veröffentlicht : 29/09/2020 10:25 pm
Nikolai
(@nikolai)
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 29/09/2020 10:27 pm
Mitglied
@bryan-b7
Like said above by Nicholai, it would be a bad idea to check your settings again.  I can’t yell you how many times I have cussed a filament for not sticking to find out the PETG I was print was using PLA settings or the wrong Z offset.
Veröffentlicht : 29/09/2020 10:41 pm
Crawlerin
(@crawlerin)
How about slowing down printing a bit? I read somewhere on their page or manual to slow down printing at higher heights through Tuning menu. Question is what's higher height 🙂 This does not look overly high. I know it's not a solution to an actual problem that may be there.
Veröffentlicht : 30/09/2020 9:30 am
NarlyB
(@narlyb)
I finally figured out the fix.
In PrusaSlicer, I turned 'Detect thin walls' on.
I first printed with another filament that resulted in the same problem.
I set the Extrusion multiplier to 0.92 and it was just a little bit better but not that much.
I then Thoroughly dried the filament at 122 F for 6 hours with no change.
I'm not sure why I tried turning on 'Detect thin walls', but the print came out awesome.
Thanks for everyone's help.
Diese r Beitrag wurde geändert Vor 6 years 2 mal von NarlyB
Veröffentlicht : 03/10/2020 4:11 am
NarlyB
(@narlyb)
One last note.  I was printing at 0.35mm Speed setting.
Veröffentlicht : 03/10/2020 4:25 am
NarlyB
(@narlyb)
If your interested, I just posted the print files for this.
https://www.prusaprinters.org/prints/42156-storage-box-2-drawer-stackable
Veröffentlicht : 03/10/2020 6:37 pm
