Print shifted in one direction after certain layer
_KaszpiR_
(@_kaszpir_)
Interesting thing happened today.
Printed one set of hinges, all ok,
then printed another and.... after certain layer everything was shifted to one direction (towards left, so it is in X axis) and anything above it was also shifted.What's interesting, some web API calls to Prusa Mini were ok (prometheus metrics), but the other were as if the printer stopped working (as a result my print video was ended before final print finish.)
Looked at the graph and I can see there is a noticeable hole in the data (and I bet this caused processing to trigger that the printer is not printing and thus render video from the captured images).
Printer is connected over the cable to the switch.... (hm... I might have moved that in that time....)
Anyone seen something like that?
Postato : 16/03/2024 10:03 pm
_KaszpiR_
(@_kaszpir_)
RE: Print shifted in one direction after certain layer
ok, looks like the error occurred around 22:05 (+- 60s), and there is nothing on the graphs 🙁
Postato : 16/03/2024 11:03 pm
What has happened to that print sheet?
You have a warp which probably lifted enough to cause a crash - what do your crash stats say?
This can be enough for the printer to lose its place and layer shift.
Cheeri,
Postato : 16/03/2024 11:47 pm
_KaszpiR_
(@_kaszpir_)
The print was firmly placed on the print bed so first layer did not separate from the bed (so this is not a first layer issue).
Nothing happened to the print sheet, it stayed in the same place as it were. So no, this is not a shift caused by a warp and print head getting stuck in the model - in such case it would be down/up and not left/right.
I know there may happen movements in Y axis when bed moves but in here it is a shift in the perpendicular axis. I know because I had print head blocked on the model once and it moved the bed back then (also it usually also rotates).
The gcode uses G90 - absolute coordinates, so I suspect something like a cosmic ray hitting part of the printer causing it to make a bit flip (probably something like https://en.wikipedia.org/wiki/Electronic_voting_in_Belgium#Reported_problems).
After printer restart I printed  the model again and there were no issues whatsoever.
Postato : 17/03/2024 6:50 am
Hoof Hearted
(@hoof-hearted)
I've never had a layer shift as pronounced as this, but i've had smaller ones. In my case I believe it was caused by over-extrusion, and the extruder crashing into the over-extruded model. I fixed the issue by reducing the extrusion multiplier in Prusaslicer.
Postato : 26/03/2024 11:04 pm
Tek
 Tek
(@tek)
Utenti
happened to me after i disabled z hop. printhead collided around the same layer over and over again.
it was a huge shift, over half build plate. normal shifts are more or less smaller.
not happening always which made it tricky.
Questo post è stato modificato 1 year fa 2 tempo da Tek
Postato : 05/04/2024 11:29 am
