Overture PETG Experiences?
mark
 mark
(@mark)
I tried some new Overture PETG on my Mini and had awful results, underextrusion, terrible bridging, and it clogged the hot end and left dust in the extruder. I had dried it beforehand. Anyone have similar or different experiences with this or other filaments? A friend has used Overture before but the new spool did not look like what he had. The surface of the filament was rough, not shiny.
I returned it and sprung for more Prusament. I wasted many hours trying to get the Overture dialed in and the Prusament I have works the first time.
Regards,
Mark
Postato : 04/04/2022 4:07 am
RE: Overture PETG Experiences?
Can't tell you what went wrong with your spool but Overture has become my go to brand for PETG and I haven't had any issues with it so far. It's certainly not unheard of that somehow people received the wrong material, and I have had my share of filament spools that didn't behave as they usually do, but so far I've been lucky with Overture.
Postato : 04/04/2022 12:55 pm
richnormand
(@richnormand)
Have used Overture PETG (black, orange and transparent) on my MK3. Works well for me.
Parameters were identical to generic PETG with a higher 5 to 10C build surface temperature for the first layer on the textured sheet. It does tend to string, as many PETG tend to do however.
Perhaps you were unlucky with a bad spool?
REPAIR, RENEW, REUSE, RECYCLE, REBUILD, REDUCE, RECOVER, REPURPOSE, RESTORE
Postato : 04/04/2022 5:51 pm
mark
 mark
(@mark)
Posted by: @richnormand
That is a possibility. It did not look like what my friend got in the past. That said, the Mini is much less forgiving than a MK3.
Regards,
Mark
Postato : 04/04/2022 6:00 pm
Do you have an unmodified Mini? Your mention of under extrusion and dust in the extruder made me wonder about the idler tension which I found to be super sensitive on the original extruder.
mark
 mark
(@mark)
Posted by: @fuchsr
Stock Mini with Super Pinda. I've got the extruder tension dialed in for Prusament at least.
Regards,
Mark
Postato : 04/04/2022 6:05 pm
It seems to work fine with Prusament for everyone as far as I can tell but it seems that for other filaments the extruder is a lot more finicky. Why, don't know. The only upgrade I truly recommend is the Bondtech dual drive extruder (or its clones; I have the Trianglelab clone). Since installing it I haven't seen any of these issues on my Minis.
Postato : 04/04/2022 7:18 pm
jsw
 jsw
(@jsw)
I've used Overture PETg on the MK3s off and on with no issues.
Generic PETg profile in PS and/or Cura.
Postato : 04/04/2022 11:26 pm
Bob
 Bob
(@bob-2)
I've used Overture with both my Mk3 and my Mini and I've always had success with it.  Having said that as it ages it does get stringy, so I try to print models that won't result in a lot of stringing, vase mode things and boxes and the like.
I did have a problem with my Mini AFTER using PETG, when shortly after switching to PLA I started getting clogging and after many failed attempts to change the hot end PTFE (pilot error, I didn't realize I hadn't gotten the heat break properly clean) I put in the Bond Tech heatbreak and things have been fine since.  My best guess is running at PETG heat caused the PTFE to shrink but that's just a guess.  YMMV.
Cheers
-Bob
Postato : 21/04/2022 1:26 pm
