[Newbie] Need more than -2.000 Live-Z Adjust when doing first layer calibration
[Resuelto] [Newbie] Need more than -2.000 Live-Z Adjust when doing first layer calibration
Matthew Schultz
(@matthew-schultz)
After successfully implementing the Silicone Mod for my Mini+ (i'm down to .02 across the board), when I do my first layer calibration, the printer wants more negative Live-Z than the limit of -2.000. (Meaning, it wants Live-Z adjustment to -2.005, -2.010, etc.)
I've tried searching the forums, but I can't find a simple/straight answer to this issue among the noise.
I'm going to try adjusting the SuperPINDA probe, but wondering if there's a known way to resolve this issue.
Best Answer by Neophyl:
No, it’s simply to move the panda sensor slightly higher. By about a full threads worth roughly. That will put your nozzle closer by the same amount as you move up the sensor. So aim for about 1mm.
Respondido : 24/04/2022 3:19 am
RE: [Newbie] Need more than -2.000 Live-Z Adjust when doing first layer calibration
Respondido : 24/04/2022 9:25 am
1 les gusta
Matthew Schultz
(@matthew-schultz)
That was my inexperienced take on it, but it makes sense. Thanks for the confirm.
Ill update the thread once I’ve done it.
Respondido : 24/04/2022 9:34 am
As @neophyl said, move the pinda higher. I made this little gadget to help get into the proper range: https://www.prusaprinters.org/prints/57192. Better than zip ties or credit cards with ill-defined heights.
Respondido : 24/04/2022 11:54 am
2 les gusta
MysDawg
(@mysdawg)
Posted by: @fuchsr
I have used this many times and it works great! Thanks for the file and design
Respondido : 24/04/2022 3:39 pm
1 les gusta
Matthew Schultz
(@matthew-schultz)
Thank you, @fuchsr! Printing now!
Respondido : 24/04/2022 3:59 pm
Matthew Schultz
(@matthew-schultz)
Update: adjusted the SuperPINDA using @fuchsr's calibration tool… and it worked beautifully. Back up and printing.
Thank you!
Respondido : 24/04/2022 10:39 pm
jbkmelk
(@jbkmelk)
Can you update the link for this file? I am having the same issues but the link doesn't work.. 🙁
Thanks
Respondido : 03/04/2023 3:01 am
Matthew Schultz
(@matthew-schultz)
Here ya go:
Super PINDA Calibration tool
Esta publicación ha sido modificada el hace 3 years por Matthew Schultz
Respondido : 03/04/2023 3:28 am
Thanks to the editor auto-adding a period at the end of a sentence to the link ☹️
Respondido : 03/04/2023 11:50 am
A simple tool to calibrate SPINDA/PINDA (Mini and MK3) height:
https://media.printables.com/media/prints/57049/images/566140_1c7a4b86-ba82-43b7-a91a-7edb89954cc4/thumbs/inside/1280x960/jpg/pinda-lehre_v1_3.webp
https://www.printables.com/de/model/57049-lehre-fur-pindaspinda
wbr,
Karl
Respondido : 03/04/2023 12:08 pm
Matthew Schultz
(@matthew-schultz)
Link works for me on my
phone, but just in case:
https://www.printables.com/model/57192-super-pinda-spinda-spinda-height-adjustment-tool-m
Respondido : 03/04/2023 1:07 pm
jbkmelk
(@jbkmelk)
Thank you. Now just need to get it low enough to be able to print!
Respondido : 03/04/2023 4:09 pm
