My first nightmare day.
Distinctly Average
(@distinctly-average)
Yesterday I spent hours in.learning fusion 360 (what a frustrating bit of software) creating an iPhone to scope mount. Printed it and it was a wonky mess. I just couldn’t understand it. So today I switched to printing some anti-vibration feet downloaded from here. It just kept failing. I re-sliced it, tried brims, did all sorts and it just kept failing after initially looking good. Cleaned and re-cleaned the bed but it still kept failing to adhere. Lots of cleaning the nozzle and block after a birds nest soup issue and my heckles were up. So I tried running first layer test and it looked terrible with half the square missing, and the other half perfect. Tried a couple of times with the same, I had gone from perfect prints every time to blooming nightmare.
So had a break, a couple of cans of temper relaxant, also known as lager, then went back to it. Funny how a break can help you spot the bleeding obvious. At some point yesterday I had re-fitted the steel sheet, probably late and in low light. I had unknowingly hooked it on one of the locating pins. Arrgggghhhhhhhhhhhh.
Felt like a total muppet, always go back to basics and think about what might have changed. Enginerding rule 1, and after a career in engineering and IT for the last 28 years I failed on the basics. Rule 2 is beer always helps.
Napsal : 23/01/2022 11:04 pm
1 lidem se líbí
Zoltan
(@zoltan)
Member Moderator
RE: My first nightmare day.
Do not worry, you are not  the first neither the last who did so 😆
Napsal : 25/01/2022 5:32 pm
1 lidem se líbí
burtronix
(@burtronix)
Ah, yes. When I started reading your problem, I was going to recommend you look for a stray piece of filament under the sheet. Glad you found the real issue.
Whatever you find to do with your hands, do with all your might!
Napsal : 09/02/2022 2:25 pm
1 lidem se líbí
