A lire IMPORTANT pour les récents Acquéreur MK Problème FAN
Je vous copie ici un text sur le ''futur'' FMW qui risque de causer des problèmes au Sunon pour ceux qui en ont, et aussi à savoir les derniers acquisition de MK si elles ne sont pas déjà équipées de ce super !!! Fan Delta
Warning
![😅](https://static.xx.fbcdn.net/images/emoji.php/v9/t53/1/16/1f605.png)
![🙂](https://static.xx.fbcdn.net/images/emoji.php/v9/t4c/1/16/1f642.png)
Why?
Will Prusa provide a fix?
![🤣](https://static.xx.fbcdn.net/images/emoji.php/v9/t52/1/16/1f923.png)
Add a switch in the LCD menu
Create a G-Code to cancel this
Add an adapter on the Prusa Mini fans to reduce their speed (like it is widely made for computers fans)
Activate the solution only for recent printers to avoid current users destroying their Sunon
Create a hidden menu you have to activate via special command and go to another menu to finally find a setup for deactivating this.
The "destroy hotend fan" will be activated when you upgrade your current Prusa firmware.
![😢](https://static.xx.fbcdn.net/images/emoji.php/v9/te/1/16/1f622.png)
How to activate the secret switch?
![😁](https://static.xx.fbcdn.net/images/emoji.php/v9/t4f/1/16/1f601.png)
Long press in "HW setup" menu.
The long press will activate a hidden menu
Access the hidden switch at the end of the setup menu
Why using a different hotend fan than the Noctua?
Inconsistent extrusion (because filament act like a spring as it gets too warm). Part of 602 issue is here.
Clog (filament stick in the heatbreak and block the extrusion).
Heat creep or partial clog (filament stick in the heatbreak and partially block the extrusion).
More stringy print (harder to tune the retraction)
Others (because I always forget about something)
But I want low noise Greg!
Could we use the Prusa Mini hotend fan in replacement of the Sunon?
What about Bear Calibration firmware?
Conclusion
You want to read more?
RE: A lire IMPORTANT pour les récents Acquéreur MK Problème FAN
Bin dites donc mais j'adore les trucs cachés comme les trappes secrètes like Dongeon Master.
Tu as essayé l'appui long au menu HW ?
Et quelle idée de mettre un Sunon en lieu et place du Noctua (à moins d'être Noctuabulophobe ah le beau mot cœur).
Le Sunon est bcp plus puissant et rapide que le Noctua, qui sont de trés bon fan , mais le Sunon permet une meilleur ventilation qui reste pas excellent déja sur le dissipateur mais bon ça fait le job..et malgré tout il n'y pas de raisons pour changer de fan et bloquer la vitesse...
Ah très bien Patrick c'était un test hum Sunon grand nom pour le watercooling ...
Une p'tite crise de jalousie de PR mais bizarre que malgré ça on peut régler le problème (c'est bien ça ?) en passant par le menu caché.
Depuis quand ils équipent les MK? Pas évident si faut démonter le ventilo pour voir le sticker signalétique.
MK3S(MMU2S), MK3S(Single), Fusion 360, Blender (débutant), Openscad
C'est du vent, je suis sur que c'est pour gratter quelques euros sur le prix du ventilo, j'ai jamais entendu dire qu'un MK ne refroidissait pas assez la tête d'impression ...
Houla là c'est la tête d'impression (la buse triple buse que je suis et aussi la couche imprimée) c'est à dire devant ou le heat-break c'est à dire sur le coté ?
Et les quelques € grattés c'est pour lequel, le Sunon ou le Noctua le moins cher ?
Et le dissipateur il faut plusss ? A ce moment là il suffit de mettre un 2ième ventilateur de l'autre coté (le fameux push-pull du watercooling) mais bon voulons-nous une usine à gaz pour notre MK3 bien-aimée (?)
Et puis plusss puissant ça fera plusss de bruit et là on ne sera pas content.
Si vous voulez plussss de ventilation il y a une solution mais gaffe espace et poids sont les 2 mamelles de krot je ne sais plus donc :
- un ventilateur de plus grand diamètre ok plusss de vent et toutitou et
- un adaptateur de diamètre qui, aussi, puisque volume généré important, par une déviation vers le devant ne gênera pas le mouvement vers la gauche du bloc extrudeur.
Houlala pas la là ça devient compliqué.
Et si, idée de mon chat hein je le signale, il suffit de changer l'étiquette du venti-délateur pour le FW qui n'y verra que du feux (chérie l'extincteur non pas sur ma gueule !).
@ claire-k : Mes chats ont la même idée que le tien. mais ce qu'ils aiment surtout, c'est mettre leur poils dans les ventilos, sur les axes sur le bed! (Hier après midi, nettoyage serrage et graissage de l'imprimante.)
Hello,
avec quoi je peux graisser les tiges et les axes du plateau ? j'ai également des probleme de poils d'animaux 😉
la graisse Prusa fournie avec ton kit, ou un lubrifiant sec type WD40 specialist lubrifiant sec au PTFE (Teflon). Sur ce dernier, la poussière n'adhère pas. je l'utilise depuis 15 jours et c'est vraiment génial et mes bout d'axes ne sont plus souillés.
Super ! Merci pour le conseil. je vais acheter ce WD40 specialist au PTFE
Pour les poils des animaux (les chats par exemple) vous pouvez :
- un les brosser pour enlever le poil d'hiver qui s'en va pour laisser la place au poil devinez d'été hé hé
- deux les baigner si si il y en a qui aime ça, ça calme la chaleur estivale de devinez d'été (on est en plein dedans)
- trois passer doucement un aspirateur sur le poil avec un flexible pour éloigner l'engin bruyant, mettre la puissance au mini pour diminuer le bruit de l'engin bruyant et lui susurrer des mots doux pour le rassurer (le chat, l'aspirateur s'en fout)
- quatre interdire l'accès ou rendre l'objet inaccessible en hauteur par exemple avec des trucs qui l'empêche de sauter sur l'espace du dit objet.
Ah si - cinq avoir si si ça existe un chat sans poil ça surprend beurk mais c'est extrêmement doux (attention votre femme risque de vous délaisser niveau câlins tellement c'est doux comme Jérôme).
Pour moi impossible, becose, rien qu'à ouvrir le placard ou est entreposé le turbo, les miens vont se planquer! Jamais compris pourquoi!
