Trouble printing tall, 131mm, and narrow part.
schesnutt
(@schesnutt)
Miembro
Please see the attached screenshot.  I am printing with PETG.  The first time I printed this, it fell over after 1/3 of the print. (131mm tall)  I added a Brim and this time it detached and rotated 45 degrees. The brim kept it upright, but you can guess the mess.  I am using KORES Glue Stick. I can print this laying down, but would have to use supports inside the tubes. Any suggestions?
Respondido : 14/10/2024 4:06 pm
RE: Trouble printing tall, 131mm, and narrow part.
You could try tilting the model at 45 degrees
It should be largely self supporting, but you need a small amount of support, to stop the model falling over.
I used paint on supports to stop the bottom sliding and to stop the slope from collapsing
DEMO PROJECT ATTACHED
Respondido : 14/10/2024 6:39 pm
schesnutt
(@schesnutt)
Miembro
Because I print parts for a product we sell, I grew used to using a glue stick to aid in the first layer and the final release.
I cleaned the print surface, flat steal, with dawn and an old scotch brite pad, dried, wiped down with 70% alcohol, added a brim and hit print. (No KORES Glue Stick) The print is complete and I am waiting for the bed to cool completely before I remove it.  Sometimes we forget why we do things......
Respondido : 15/10/2024 2:01 pm
I Didn't comment on the Gluestick as some people are Attached  to it...
Lol
Respondido : 15/10/2024 2:20 pm
1 les gusta
Sembazuru
(@sembazuru)
Another thing to look at is print orientation. It looks like you have the wide axis oriented perpendicular to the bed y axis. For tall, narrow prints I usually try to put the wide axis parallel to the bed y axis. The narrow axis in the orientation I see in your screenshot won't give much resistance to wobbling as the bed moves back and forth, but if you have the wide axis parallel to the bed y axis it should provide more support from wobbling.
See my (limited) designs on:
Respondido : 21/10/2024 11:37 pm
