Trouble printing tall, 131mm, and narrow part.
Please see the attached screenshot. I am printing with PETG. The first time I printed this, it fell over after 1/3 of the print. (131mm tall) I added a Brim and this time it detached and rotated 45 degrees. The brim kept it upright, but you can guess the mess. I am using KORES Glue Stick. I can print this laying down, but would have to use supports inside the tubes. Any suggestions?
RE: Trouble printing tall, 131mm, and narrow part.
You could try tilting the model at 45 degrees
It should be largely self supporting, but you need a small amount of support, to stop the model falling over.
I used paint on supports to stop the bottom sliding and to stop the slope from collapsing
DEMO PROJECT ATTACHED
Because I print parts for a product we sell, I grew used to using a glue stick to aid in the first layer and the final release.
I cleaned the print surface, flat steal, with dawn and an old scotch brite pad, dried, wiped down with 70% alcohol, added a brim and hit print. (No KORES Glue Stick) The print is complete and I am waiting for the bed to cool completely before I remove it. Sometimes we forget why we do things......
I Didn't comment on the Gluestick as some people are Attached to it...
Lol
Another thing to look at is print orientation. It looks like you have the wide axis oriented perpendicular to the bed y axis. For tall, narrow prints I usually try to put the wide axis parallel to the bed y axis. The narrow axis in the orientation I see in your screenshot won't give much resistance to wobbling as the bed moves back and forth, but if you have the wide axis parallel to the bed y axis it should provide more support from wobbling.
See my (limited) designs on:
