Color Bleed MK4S MMU3
sinisan14
(@sinisan14)
Hello, I am having color bleed issues that are especially visible in lighter colors.
Would ticking the "Infill before perimeters" option help? It makes sense to me that the next color purges a bit of the old color in the infill and by the time it prints the walls the bleed is gone. I haven't tried this yet but does that make sense?
Respondido : 02/04/2025 1:18 pm
LarGriff
(@largriff)
Purge Volume needs to be increased.  Also, be aware that if you have a High Flow nozzle you will need to increase the purge volume a LOT.  Check that the High Flow setting (in PrusaSlicer) matches what is installed.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Respondido : 03/04/2025 2:26 pm
sinisan14
(@sinisan14)
RE: Color Bleed MK4S MMU3
My current purging volume is set to 240mm3 with the color bleed. The default is at 140, how much should it be for a HF0.4 nozzle?
Respondido : 03/04/2025 2:46 pm
the MMU3 works better with a standard flow nozzle, can you change the nozzle to a standard nozzle?
Respondido : 03/04/2025 5:45 pm
1 les gusta
LarGriff
(@largriff)
Yeah, if you have a high flow nozzle you may need more like 300-400 if you’re going from red to white.  Especially if you’re  using PETG.  No wonder the standard nozzle is recommended.  Here’s a tool that has helped me determine purge volumes.
https://www.printables.com/model/1147770-easy-mmu3-purge-calibration-tool-for-mk4-and-other
Respondido : 03/04/2025 5:59 pm
