Behind Curve w/ MK4 Ad-Ons!
moell
(@moell)
Where / how to start?  I have been delayed for several weeks - various reasons.  From reading various posts, there may be overlap on getting the entire system, noted below, assembled?
Comments appreciated if you have time.  Thanks.  Current Status:
  • MK4 in original config. - works great
  • MMU3 on site, still in boxes
  • MK4S upgrade ordered, not received
  • Enclosure on site, partially assembled, printer not installed
Publié : 13/10/2024 5:07 pm
JP Guitars
(@jp-guitars)
RE: Behind Curve w/ MK4 Ad-Ons!
I would say work through the builds in an order that minimises the change at each step and gives you the easiest problem solving. I would do it in this order:
  1. MMU, mine was a bit fiddly to get switching well. If you do it first you are fiddling with stuff you know
  2. MK4S not done it myself
  3. Enclosure. Once the printer is in the enclosure access is reduced so sort everything else out first when you can get to things
Publié : 13/10/2024 5:21 pm
moell
(@moell)
I'm really not sure why I even ordered the enclosure?
Publié : 13/10/2024 5:30 pm
JP Guitars
(@jp-guitars)
I like mine, but I print a lot PETG.
But even when I print PLA when I leave the doors open to keep it cool, it cuts the noise down which is good for overnight prints
Publié : 13/10/2024 5:50 pm
