Behind Curve w/ MK4 Ad-Ons!
Where / how to start? I have been delayed for several weeks - various reasons. From reading various posts, there may be overlap on getting the entire system, noted below, assembled?
Comments appreciated if you have time. Thanks. Current Status:
- MK4 in original config. - works great
- MMU3 on site, still in boxes
- MK4S upgrade ordered, not received
- Enclosure on site, partially assembled, printer not installed
Posted : 13/10/2024 5:07 pm
RE: Behind Curve w/ MK4 Ad-Ons!
I would say work through the builds in an order that minimises the change at each step and gives you the easiest problem solving. I would do it in this order:
- MMU, mine was a bit fiddly to get switching well. If you do it first you are fiddling with stuff you know
- MK4S not done it myself
- Enclosure. Once the printer is in the enclosure access is reduced so sort everything else out first when you can get to things
Posted : 13/10/2024 5:21 pm
Topic starter
answered:
I'm really not sure why I even ordered the enclosure?
Posted : 13/10/2024 5:30 pm
I like mine, but I print a lot PETG.
But even when I print PLA when I leave the doors open to keep it cool, it cuts the noise down which is good for overnight prints
This post was modified 4 hours ago by JP Guitars
Posted : 13/10/2024 5:50 pm
