XY failed
6ejiuap
(@6ejiuap)
XY failed
IMG_3137
Hello, help pls.
Opublikowany : 21/01/2025 6:13 pm
miroslav.h4
(@miroslav-h4)
RE: XY failed
On the X-axis you can see a poorly mounted pulley, the Y-axis pulley is not visible, but it will probably be the same. Instead of asking here, take the building instructions to hand, carefully read in what position the pulleys should be mounted on the engine axis and see how you have them mounted.
Opublikowany : 22/01/2025 5:14 am
Ineal
(@ineal)
RE: XY failed
the last what i want is frustrating on Prusa Printers, this are good products and the help is very good if needed.
i make same mistakes even if i build it the second time i will jump over and miss that part
On every manual in Capture one there is always nearly the same wrote:
is this a hint when i say "flat surface", i think no, is time to read all captures again to find the Problem and maybe the hint
Opublikowany : 22/01/2025 8:37 am
chmax
(@chmax)
RE: XY failed
Hi @miroslav.h4 pardon me for asking, by which visual clue do you see the X pulley being poorly mounted? I reviewed the pictures in the assembly guide and they look exactly like the one in the video?
Opublikowany : 22/01/2025 9:50 am
Ineal
(@ineal)
RE: XY failed
@chmax look closley the two screws and the flat surface, if u know the the manual, u know where they have to bee
same error on Y but there no screw is tight enougth
Opublikowany : 22/01/2025 10:14 am
Ineal
(@ineal)
RE: XY failed
Opublikowany : 22/01/2025 10:19 am
1 ludzie polubili
chmax
(@chmax)
RE: XY failed
oh I see, no screw is sitting on the flat part of the motor shaft. Good catch, it was not immediately visible in the video but going much slower I did catch that. Thanks for the clarification.
Opublikowany : 22/01/2025 10:29 am
6ejiuap
(@6ejiuap)
RE: XY failed
I did everything according to the instructions and really didn't realize that there were screws that needed to be tightened, my fault 🙃 .
Thank you all, you really helped! 😎
Opublikowany : 22/01/2025 12:27 pm
Ivan Mikeska
(@ivan-mikeska)
RE: XY failed
I have a faulty X-axis selftest, so far I have not had a problem with it, the printer has printed without a problem. I tried adjusting the belt, cleaning the guide rods, checking the bearings and it still does not work. Can you advise me? I have a MK4 with a box.
Thank you
Opublikowany : 22/01/2025 12:33 pm
Ivan Mikeska
(@ivan-mikeska)
RE: XY failed
a few photos
Opublikowany : 22/01/2025 12:36 pm
Ineal
(@ineal)
RE: XY failed
belt tension or issu sit normaly a little higher on second picture where the cable cover is
but i can't see not normal, video to short or picture on wrong details
Opublikowany : 22/01/2025 2:49 pm
Ivan Mikeska
(@ivan-mikeska)
RE: XY failed
the belt test was good
I took the cover off for photo purposes.
What photo should I take?
Opublikowany : 23/01/2025 6:40 am
prusa3d.r9qi6
(@prusa3d-r9qi6)
RE: XY failed
I'm new to Prusa and just assembled the MK4S.  I'm running into the same issue. Talked with customer support and we looked at everything but can't get XY test to pass.  X-axis fails ,  Y-axis passes but it won't even do Z which I assume is dependent on X?. Does anyone know whether you can actually set X to a desired value that the self test is actually measuring or manually calibrate. The machine prints stuff fine but every time I turn it on or trying to print it gives the calibration and self test warning and there seems to be no way to turn it off.
Last resort is disassembling and redoing again if  X and Z passing the self-test is critically important to the long term functioning of the printer.
Opublikowany : 28/03/2025 7:25 pm
