PETG blobs on MK4
CarlosAndrade981
(@carlosandrade981)
Utenti
PETG blobs on MK4
Hello, I am struggling to print anything with PETG, since it seems to consistently generate blobs after the first few layers. I tried reducing the extrusion multiplier to 0.95, and then to 0.92, but this did not work at all. The brand I used was Overture, and I used the generic PETG profile, with the only changes being the aforementioned ones to the extrusion multiplier.
Postato : 24/05/2024 10:05 pm
RE: PETG blobs on MK4
Assuming the nozzle is clean, did you try running a non-IS profile?
Postato : 25/05/2024 12:17 am
CarlosAndrade981
(@carlosandrade981)
Utenti
I managed to fix it, by setting the extrusion multiplier all the way down to 0.85.
Postato : 25/05/2024 3:13 am
ssill2
(@ssill2)
wow.   .85.   that's pretty crazy.   My paramount 3d petg filament makes me go to .95, but that's the lowest I've ever had to do. Most of my petg brands require .96/.97  to avoid blobs.   Clean nozzle is definitely important.
I think for overture I use .96.  I usually start with the prusament profile and then adjust temp and extrusion multiplier to get where I want to be.   have you tried drying your filament?
Postato : 08/06/2024 2:27 pm
