How can I get better quality on the bottom part of a print, when there are supports?
jbroggio
(@jbroggio)
Hello,
I am aware you are obviously never going to get prints that look as good under a support as you will on top, but are there any settings I can tweak in the profile to get better-looking prints when detached from supports? They are pretty rough on the bottom and I wish I could tighten the quality up even just a little.
Thanks!
Opublikowany : 31/10/2023 12:17 am
RE: How can I get better quality on the bottom part of a print, when there are supports?
Not much you can do, you're fighting gravity. You can play with the top z separation distance or the number of interface layers (to make removal easier). Dropping the temperature a bit may also help a bit (I have a new print-in-place design where I need to go down 15 degrees from my default to have the parts separate) but I wouldn't expect any profound improvement
Opublikowany : 31/10/2023 11:19 am
