Switch from 5.0.0 alpha to 4.6.4 FW not possible via usual process
Print4Fun
(@print4fun)
Good morning fellow printers and makers,
I am having issues with installing the new 4.6.4 FW (or any other FW version) on my MK4 after having installed the  5.0.0-alpha1 firmware w. Input Shaping.
I started with the Prusa factory installed 4.6.2 which worked great, switched to the 5.0.0 alpha and tried to reinstall the 4.6.2 also, which did not work either.
I use the installing method of putting the *.bbf file with the FW version I want to install on my printer to the USB stick via my PC (in the root folder not any sub folder). And I make sure to only have the one new FW version file I want to be installed on the stick. Then I insert it into the Mk4 and restart; it will continue either to:
A) just normally start and show me the 5.0.0 alpha start screen or
B) if I keep the control button pushed during restart* (after logo is showing) - to also just normally start and show me the 5.0.0 alpha start screen
Does anyone know this issue and could please help me to solve it?
Is there another way to try to get another FW version to my MK4?
Thanks for your feedback and have a nice day.
KR
P4F
* As described in the official manual:
"To force a firmware installation (e.g. if you need to load an older firmware), insert the USB drivecontaining the desired .BBF file, restart the printer, wait for the logo to show up and press andhold the control button during the system startup until the firmware installation screen appears."
Opublikowany : 22/06/2023 7:25 am
Walter Layher
(@walter-layher)
RE: Switch from 5.0.0 alpha to 4.6.4 FW not possible via usual process
You need a double press of the knob, not a long press. Look here: https://forum.prusa3d.com/forum/input-shaping/revert-back-to-stable-firmware/
Opublikowany : 22/06/2023 8:28 am
Print4Fun
(@print4fun)
Thanks a lot Walter, issues solved 🙂 So I guess Prusa should update this in the Mk4 manual - it is not holding the knob but just pressing it two times.
Opublikowany : 22/06/2023 10:18 am
