PrusaConnect "offline"
Mike
 Mike
(@mike-34)
I'll start by saying the PrusaConnect is improving to the point where I don't really miss Octoprint anymore.  Having said that, there is an annoying issue where for no apparent reason, my MK4 printer goes "offline."  It seems to happen (but not always) when I print something manually from the MK4 control panel.  The printer shows as still being connected to my wireless network but it stops being visible to PrusaConnect.  Is anyone else having this issue?
-Mike
Publié : 18/07/2023 2:35 pm
Hello
(@hello)
RE: PrusaConnect "offline"
I get a similar issue connect says offline but pruss link is online and says dns error vonecting yknprusa connect
Publié : 18/07/2023 7:50 pm
Smutje
(@smutje)
Same here, online in Prusa Link, and offline in Prusa Connect
Publié : 23/07/2023 10:52 am
Mike
 Mike
(@mike-34)
I've been getting it a lot since upgrading my firmware to the stable 5.0 version.  Interestingly, I can still download files and the print happens anyway, I just don't get telemetry and the status shows "offline."
Publié : 22/09/2023 2:28 am
1 personnes ont aimé
SaveYourBacon
(@saveyourbacon)
Same here for my Mini and MK4 (much more often for the Mini)... I wish Prusa would at least publicly acknowledge the issues so I can stop thinking it is an issue on my side.
Publié : 25/09/2023 1:38 am
moofie
(@moofie)
I've been having the same issue since upgrading to 5.0 release firmware.
Publié : 25/09/2023 3:04 am
Brian-J
(@brian-j)
Membre
I Agree I wish Prusa would reply to this thread, i'm having the same problem with connectivity
Publié : 26/09/2023 2:00 pm
inmyTEEPEEitsme
(@inmyteepeeitsme)
Wish Prusa would say something.  Having the same issue since upgrading my MK4 to 5.0.0 connecting to PrusaConnect.  Prusa Link works fine, but PrusaConnect shows me offline more than not.
Either it is an issue with PrusaConnect or the firmware, wish they would publicly state something.
Publié : 26/09/2023 8:01 pm
PRNTR3D
(@prntr3d)
I have been getting the same, usually, I have to reload the wifi and connect settings to get it to connect again.  although that is temporary until it goes offline again.
Publié : 29/09/2023 12:33 am
SaveYourBacon
(@saveyourbacon)
inmyTEEPEEitsme, I was coming here to post the same... I spent a fair amount of time troubleshooting my local setup. I wish Prusa would at least acknowledge the issue.
Publié : 29/09/2023 12:43 am
moofie
(@moofie)
Take a look at the pinned post at the head of this forum.
Publié : 29/09/2023 1:20 am
SaveYourBacon
(@saveyourbacon)
I'm sorry but I don't see what you are referring to... would you mind posting a link?
Publié : 29/09/2023 1:28 am
moofie
(@moofie)
My error, different forum.
https://forum.prusa3d.com/forum/bugs-errors/mk4-xl-mini-printer-offline-or-unable-to-register/#post-676516
Publié : 29/09/2023 2:55 am
moofie
(@moofie)
I mentioned this in another branch, but in case you haven't seen it:
SaveYourBacon
(@saveyourbacon)
Thank you!
Publié : 29/09/2023 3:06 am
dankat
(@dankat)
Membre
I am still having the issue described in the OP. When i press 'print' from my MK4S LCD screen, instead of marking the printer as ready via Prusa Connect, my printer then appears as 'offline' on the web version and mobile app of Prusa Connect. Very strange! I've just upgraded my firmware to 6.2.0, maybe that caused it?
This seems to be a slightly different issue from the one in the other thread mentioned above.
Publié : 06/02/2025 5:27 pm
sandysasmita
(@sandysasmita)
try to change DTIM settings on your router, usually this menu are in 2.4ghz wireless section. change the value higher let's say 125 save it and see if your problem solved.
Publié : 10/03/2025 7:37 am
beddom
(@beddom)
Membre
Thanks, I have Tp-Link AX3000 and value that i can set is between  1 to 15.
Publié : 03/06/2025 11:32 am
Saik Caskey
(@saik-caskey)
Membre
Selecting 'set ready' manually seems to impact it for me (i.e., seems to break and or fix my connection) Could just be some bug after losing connection locally. Something to note - I think the mobile app can show a different status than the desktop app in those cases, maybe the desktop app is just falling back to saying 'Offline', or they both show their last valid state received until they get a new one
Publié : 03/10/2025 5:39 pm
Artoriaz
(@artoriaz)
Membre
I had this before, and I solved it by rechecking my PrusaSlicer > configuration (make sure you select the right exact model).
Publié : 04/10/2025 3:37 pm
