LCD going black and flashing white occasionally after boot
DavidBanni
(@davidbanni)
Mitglied
I built my kit and printed a few items. Next time I boot the screen failed half way through the boot progress.
I flashed the firmware up to 5.1.0 and I booted successfully. Started the printer later that day to do a print and the screen was black again after boot.
Today I tried to use it and I got to the home screen, but then navigating to Filament it went black again.
This inconsistency is really frustrating, is there a fix?
Thanks,
David
Veröffentlicht : 28/11/2023 9:10 pm
DavidBanni
(@davidbanni)
Mitglied
RE: LCD going black and flashing white occasionally after boot
The UI also froze trying to unload filament mid-print, but that's presumably a separate bug.
Veröffentlicht : 28/11/2023 9:11 pm
colbymg
(@colbymg)
Mitglied
Any resolution? I think I have the same problem (though mine is a MK3.9 upgraded from MK3s):
Screen flickers between black and white, sometimes when I scroll it'll display the icons and options selected but then sometimes go black/white again, sometimes will display options upside down.
Tried resetting to factory and installing a fresh 5.1.2: worked perfectly on next boot, but then problem resumed for all subsequent boots.
It started pretty randomly... The only thing I remember doing differently around that time was assigning the printer a dedicated IP in my router (kept giving itself new IPs every so often, which made PrusaLink and the length of the uneditable password a real pain). But I undid that setting and it still has issues.
Prints totally fine once I luck into getting to that point.
Figure next step is to unplug and replug all the LCD cables, then contact support.
Diese r Beitrag wurde geändert Vor 2 years 3 mal von colbymg
Veröffentlicht : 04/01/2024 11:31 pm
ironfan72
(@ironfan72)
I'd definitely recommend you take some videos the next time it happens and contact support. I had this happen to me and a new LCD fixed the problem.
Veröffentlicht : 05/01/2024 5:45 pm
DavidBanni
(@davidbanni)
Mitglied
Hey,
I had the PE cable on the lcd in the wrong orientation.
Veröffentlicht : 05/01/2024 7:19 pm
colbymg
(@colbymg)
Mitglied
Some video:
K, will do, thank you
Veröffentlicht : 05/01/2024 7:51 pm
BM
 BM
(@bm-2)
Same probleme here with my mk3.5... I will contact the support.
Veröffentlicht : 20/02/2024 8:50 pm
colbymg
(@colbymg)
Mitglied
Update on my experience:
I tried updating the firmware, downgrading the firmware, replugging the LCD/board cables, resetting to factory settings (all with support's support).
Resetting to factory settings seemed the most promising at first - it'd work like normal for 2-6 startups, then issue would resume.
After trying all that, support offered to send a replacement xLCD. It arrived a few weeks ago, I installed and wanted to give it a few startups to be sure it's still working, and it's still working perfectly.
Always love interactions with prusa support (when unfortunately required) - they usually suggest things already tried, but are very persistent to solve the problem and I love how willing they are to just replace parts!
Veröffentlicht : 21/02/2024 4:21 am
drees nice
(@drees-nice)
Mitglied
I have a very similar issue (MK4)
https://youtube.com/shorts/_OYCGT-OVJU?feature=share
Posted by: @colbymg
Some video:
Ps; how do i integrate the yt clip as video instead of just the link?
Veröffentlicht : 21/02/2024 12:57 pm
Tomek
(@tomek)
Mitglied
I had a similar problem with the lcd. After speaking to support it turned out that the display was to be replaced. I received a new lcd within a few days. The new display has a different ribbon routing on the back. Perhaps this was the problem. I hope the new lcds will be better.
I have about 20 days printed on my printer.
Diese r Beitrag wurde geändert Vor 2 years 2 mal von Tomek
MK4
Veröffentlicht : 12/03/2024 1:29 pm
ts.maerkl
(@ts-maerkl)
Hello everyone,I assembled the kit a few days ago and yesterday the display suddenly started to flicker and finally failed completely.
I found a few older threads here in the forum describing a similar problem with type B boards. My display is type A.
I have now completely disconnected the ribbon cable from the power cables as there was talk of interference, but the problem persists.
Out of desperation, I have replaced the USB stick with a different model and lo and behold, the problem no longer occurs.
Has anyone had a similar experience?
I am asking because I fear that a new display won't solve the issue
Veröffentlicht : 18/03/2024 9:22 pm
ts.maerkl
(@ts-maerkl)
Quick update: the problem occured less with a new USB stick, but still occured from time to time.
I contacted the service and received a new display. It seams like this solved the problem for me
Veröffentlicht : 26/03/2024 9:59 am
drees nice
(@drees-nice)
Mitglied
I don't have the problem anymore. At all. And i use the printer near-daily.
Veröffentlicht : 30/03/2024 1:25 pm
