Firmware 6.4.0: Not sliced for IS
Ian Harris
(@ian-harris)
Updated one of my Mk4's to firmware 6.4.0 and tried a test print - now getting an information message that the file is not sliced for Input Shaping.
How do I turn off this message on the printer? I do not use Input Shaping and none of the files I have are sliced for Input Shaping.
Ian
Postato : 27/11/2025 9:20 am
Ian Harris
(@ian-harris)
RE: Firmware 6.4.0: Not sliced for IS
OK, found the setting, need to change the gcode check for Input Shaping to 'None'.
Ian
Postato : 27/11/2025 9:34 am
TheWortLord
(@thewortlord)
Utenti
I'm having the same issue. I also do not use IS 99% of the time. Is the setting you changed in the slicer or on the printer?
Postato : 29/11/2025 5:45 pm
Ian Harris
(@ian-harris)
On the printer - Settings, Hardware, G-Code Checks, Input Shaper. Press knob to get to 'None', then Returns to get back to the home screen.
Ian
Postato : 29/11/2025 11:54 pm
TheWortLord
(@thewortlord)
Utenti
Amazing, thank you!! This was driving me crazy!
Posted by: @ian-harris
Ian
Postato : 30/11/2025 2:59 pm
loadinglevelone
(@loadinglevelone)
I'm curious, setting that setting to 'none' seems to only disable the warning - yet the warning says that the g-code is incompatible. Why warn us, if the code is in fact compatible?
My printers: Mk3s / Mk3s clone with +upgrdaes (you know SPinda and all that good stuff) / Mini+ / Ender 3 v2
Postato : 17/01/2026 9:23 pm
Evelien
(@evelien)
Utenti
I am wondering the same. Why would my gcode suddenly be incompatible just because I updated the firmware?
I don't want to use IS because compared to the legacy profile it is LOUD on my Prusa Mini.
Postato : 28/01/2026 9:51 pm
dameion.d
(@dameion-d)
I'm amazed that the printer firmware and the slicer are not kept in sync, especially with Prusa Connect where the slicer knows the printer's setting. This should be an easy fix and not require users to modify their printer settings individually.
Postato : 22/02/2026 6:38 am
