Does wifi work on 5GHz or only 2.4GHz?
agdemars
(@agdemars)
I wasn’t able to get my MK4 wifi to connect to my 5GHz wifi network but it works on the 2.4GHz network. Is it supposed to work with 5GHz wifi?
Respondido : 09/05/2023 12:45 am
Artur5
(@artur5)
RE: Does wifi work on 5GHz or only 2.4GHz?
I don't own a MK4 but my uneducated guess is that it won’t. That’s based on personal experience because, even if my router works with both 2.4 and 5GHz bands, of the devices that I connect to the network, only my Xiaomi phone supports 5GHz. My two Canon printers, mini computer, Sony camera and Voron 3D printer will connect only at 2.4GHz, so I expect that Prusa’s very-slow-wifi won’t support 5GHz either  I can be wrong of course. Let's see what other MK4 users can say about this.
Respondido : 09/05/2023 9:49 am
I believe it uses an ESP32-WROOM-32 module, which does not support 5 Ghz.
Respondido : 09/05/2023 11:15 am
1 les gusta
Jeremy
(@jeremy-3)
2.4 only - but it's so slow it's borderline useless (same with eth) so plan on either USB or Octoprint.
Respondido : 09/05/2023 2:24 pm
Walter Layher
(@walter-layher)
I did not look under the cover of mine when it was still outside the enclosure, but from what I see in the photo in this article, it is an ESP-01S, which uses an ESP8266. Boards with ESP32 can support a live camera stream over Wi-Fi, e.g. the ESP32-CAM boards. Those should be a lot faster.
Respondido : 09/05/2023 2:31 pm
Yes, WiFi speed is painful. It's a bit better with the latest firmware but still embarrassing. Ethernet is in my hands about 3x faster and doable.
Respondido : 09/05/2023 3:30 pm
Ian Harris
(@ian-harris)
The wifi module plugs in - so maybe there is a faster module that may be available in the future?
Ian
Respondido : 10/05/2023 11:59 am
Walter Layher
(@walter-layher)
Probably Raspberry Pis for Octoprint will be cheap again before that, I think. 🙂
Respondido : 10/05/2023 12:02 pm
Crab
 Crab
(@crab)
depends where the bottleneck is.. If it is in the wifi module, or further down in the architecture..
Posted by: @ian-harris
Ian
Respondido : 10/05/2023 7:22 pm
Antimix
(@antimix)
No way while MK4 will use the ESP8266 (that is 2.4GHz), and an even slower SERIAL communication between the board and the ESP8266...
Respondido : 17/05/2023 10:29 pm
Dubravko Penezic
(@dubravko-penezic)
Ok, the first question was about connecting MK4 to 5GHz WiFi, so it cannot be done using the existing WiFi module, simply because that module doesn't have support for 5 GHz. Also, that module indeed communicates via Serial protocol to the microcontroller. Additional Serial protocol isn't fast, and it certainly isn't developed with speed in mind.
In my view, I think that the Prusa development team created additional features without sacrificing any existing things because the serial port is standardly available on the CPU and ESP 01 is one of the first modules for Serial to WiFi support at a very reasonable price at less than 2 US$.
If you need to connect to 5GHz WiFi network even if you need something more than standard WPA-PSK I will suggest using some personal ADSL or mobile network router with WiFI and wired port/s (you may go very cheap for less than 20 US$ buying some used or old one).
Respondido : 21/01/2024 8:21 pm
