[Solved] Banging noise on print
Lyra
 Lyra
(@lyra)
My MK4 is suddenly making a banging sound during print. Because it did not do thatsince assembly. I assume it is not good but I can not localize where the sound comes from.
https://photos.app.goo.gl/8VQAvHuLvyYH2XA97
I am new to 3D printing and this is my first printer. I build it last week from the KIT version. Can somebody help me?
Napsal : 16/08/2023 11:50 am
Lyra
 Lyra
(@lyra)
RE: Banging noise on print
Ok,  a little bit after the video and post I noticed that it is no longer extruding. A piece of filament got stuck. I manged to get it out after removing the heater block. (Neither cold pull nor an actupuncture needle helped)
My question now is: Why did this happen?
My current guess would be heat creep. The printer runs enclosed because of noise and it worked out fine for the last week, but this week it is hotter here. It was Prusament PLA. Could this be the case?
Napsal : 16/08/2023 1:11 pm
yes elevated temperatures can cause heat creep
Joan
Napsal : 17/08/2023 8:21 am
Lyra
 Lyra
(@lyra)
Thanks 🙂
Napsal : 17/08/2023 9:37 am
