MK4 Z-motors getting warm
javalabg
(@javalabg)
Not a big issue, but I'm wondering why the Z-motors are getting much warmer than the other motors (which having more or less room temperature). For me ist seems that the idle-current is set hoo high in the firmware, I would expect a higher temperature on the XY motors.
Can someone confirm the higher temperatture?
Posted : 30/05/2024 11:10 am
javalabg
(@javalabg)
Answering myself: the Z-Motors are not released in standby-mode, whereas all others are released.
So the next question: is this normal ? There is a menu option: "switch off motors" but doesn't affect the Z-motors.
Posted : 30/05/2024 11:24 am
mbezzo
(@mbezzo)
RE: MK4 Z-motors getting warm
Curious as well - I definitely noticed this and was a bit bummed.  My previous MK3S+ definitely did not do this.  I've put the printer on a switchable outlet now so I can control it, but I'd really rather just leave it on like I did before.  Seems to pull about 11w at idle now (presumably as the Z-motors are still on) - don't recall what the MK3S+ was but it was a lot lower...
I spose we should submit support tix - "is this a bug or a feature?" 🙂
Posted : 30/05/2024 10:57 pm
javalabg
(@javalabg)
Thank you for the info about the 11 (wasted?)Watts. Yes, I'll contact the support and let you know what statement I'll get.
Posted : 31/05/2024 9:18 pm
mbezzo
(@mbezzo)
Looking forward to hearing what they have to say!
Posted : 04/06/2024 11:05 pm
Gunter
(@gunter-2)
+1 !
It's waste of energy but may also have negative effect on the life expectancy of the Delta PSU and the Z-motors.
Obviously z-axis holds it position when Z-motors are really off, so why keep them powered?
Posted : 05/06/2024 5:32 am
Z motors on, is design intent, to reduce the chances of Z droop whilst you are working on the Printer...
it was active on my mk1, years ago... and remains so.
Posted : 05/06/2024 6:00 am
Gunter
(@gunter-2)
Hi @joantabb
okay, I got your point, this explains, why z-motors are not switched off automatically.
Nevertheless, when there is a menu option: "switch off motors", I would expect the machine to do so.  Of course, in this case, the printer first has to verify z-position, same as if it was power cycled, before going back into operation.
Posted : 05/06/2024 1:29 pm
That only switches off XY And E motors
Regards joan
Posted : 06/06/2024 11:18 am
