Belt Tension Gauge for PRUSA
Antimix
(@antimix)
Hello,
I built this Belt Tension Gauge for Voron.
On the site there are the standard values for Voron and NEMA motors. There is also a video on how to assemble here.
I purchased also the kit with the metal parts and wire to be sure they were the correct parts. It seems well done, works well, and the measurements are consistent during the time.
I measured the tension on my MK4 and MK3.5 that were tuned with the App PRUSA Acustic belt tuner.
On the MK4    I have: -> X = 2.5   Y = 2.35
On the MK3.5 I have: -> X = 2.6   Y = 2.5
- Is there anyone else that built this gauge and measured the values for a PRUSA printer ?
Ideally a brand new PRUSA assembled would be a good candidate for measuring the belt tension.
Regards
Publié : 03/09/2024 11:03 pm
3 personnes ont aimé
Most of us use:
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
Despite the name it also works for Mk4
It MUST be printed in Prusament PETG or the spring tension will be wrong.
Publié : 04/09/2024 6:20 am
Antimix
(@antimix)
RE: Belt Tension Gauge for PRUSA
Hi, yes I know it and I used it before. 😉
But I wanted to have a more precise measurement, for this reason I built the new device.
Best Regards.
Publié : 04/09/2024 11:27 am
1 personnes ont aimé
James D
(@james-d-2)
Membre
Hi, I use you belt tensioner for my Voron, and I just tested my new XL out of the box and I got the following, which seems to be inline with other Prusa's
X: 2.5
Y: 2.5
Publié : 21/12/2024 6:52 pm
PF Makes
(@pf-makes)
Membre
Thank you for sharing this data  with the community!  If I can get a few more measurement samples from the community the XL (I don't own one unfortunately) I will get these values added to the Github and manual.  It is looking like 2.5 on the meter is a pretty solid starting point.
Best regards,
-PF
Publié : 06/03/2025 8:19 pm
Antimix
(@antimix)
I think it will be very important during the CORE One kit assembly.
Best Regards
Roberto
Publié : 07/03/2025 6:47 pm
Nicotina52
(@nicotina52)
Membre
I'm also very interested in knowing the correct value to best set up my Core ONE kit.
I've tried using both the Prusa app and the Gates app, but I always get inconsistent values. This tool, on the other hand, is exceptional, so I’d really like to know what tension corresponds to the 85 Hz detected with this tension gauge.
Publié : 06/07/2025 7:08 pm
