Will carbon or glass fibers in nylon printed pulleys destroy belts
Jeffrey Benson
(@jeffrey-benson)
I'm having a hell of a time printing timing pulleys with a large flat surface using bare nylon, even on a petg raft.  I've had much better luck with CF PA, but I heard that the fibers can destroy belts.  Is that correct?
Napsal : 21/04/2024 3:33 pm
Just rub over the bearing surfaces with fine wet and dry paper used wet - once the surface fibres are gone wear will be slowed to the rate at which fibres are exposed as the matrix wears - ie. slowly.
Napsal : 21/04/2024 5:42 pm
2 lidem se líbí
