Stringing problem with PETG filament
Nicholas185Smith
(@nicholas185smith)
Utenti
Hello everyone,       BallSportsGear
I have been trying to print with PETG filament on my Prusa i3 MK3S printer, but I have a lot of stringing and oozing issues. The strings are thin and hard to remove, and they ruin the surface quality of my prints. I have tried to adjust the retraction settings, the temperature and the speed, but nothing seems to help.
Does anyone have any tips or tricks to reduce or eliminate stringing with PETG filament? I have heard that increasing the travel speed and using a coasting feature might help, but I am not sure how to do that in PrusaSlicer. Any advice or suggestions would be greatly appreciated. Thanks in advance!
Best regards,
Nicholas185Smith
Postato : 27/02/2024 11:21 am
Walter Layher
(@walter-layher)
RE: Stringing problem with PETG filament
Did you dry your PETG filament? This is the first step you should do with PETG, no matter if it is fresh out of the bag or not.
Postato : 27/02/2024 11:39 am
1 persone hanno apprezzato
Thejiral
(@thejiral)
PETG (and also PCTG) is the worst of the common filaments in regards to stringing. It is probably impossible to print it without any kind of stringing but if everything works fine, the stringing is very minor and won't cause any surface defects.
If you already tried retractions, temperature and speed, one more thing you can try is optimize the z-lift, if you have one. One can also try no z-lift at all. That increases risk of collissions but can help against stringing.
The most important thing however: Dry your filament.
It doesn't matter if its brand new, freshly opened, or not, perfectly stored in a dry box or not. Dry it again. And dry it long. Right before the print and then try your optimal conditions again.
The wetter PETG gets, the worse the stringing becomes. If your PETG stringing is out of control, you  can't be paranoid enough when it comes to dryness of the filament.
Postato : 27/02/2024 11:43 am
Robin
(@robin)
Postato : 27/02/2024 3:58 pm
Crab
 Crab
(@crab)
Your nozzle could be too hot.. dry dropping 10C.. I’ve also had stringing in PETG when my nozzle gets worn.. Are you using brass nozzle and if so, how old is it.. do you print filament with abrasives in it? (Wood, metal, etc). PETG generally prints very well on my MK3S+.
Postato : 27/02/2024 9:28 pm
Jasper Wilde
(@jasper-wilde)
Utenti
In PrusaSlicer, you can try increasing the print speed to help reduce chaining. At the same time, use the retraction feature to pull out the plastic thread before moving to a new position, thereby reducing the risk of stringing. You can find these settings in the "Filament Settings" section of PrusaSlicer.
enneagram test
Postato : 02/05/2024 9:57 am
Johnnie53
(@johnnie53)
Utenti
Did you find answer?
Postato : 03/05/2024 9:51 am
Johnnie53
(@johnnie53)
Utenti
Any Update.??
Posted by: @johnnie53
Postato : 06/05/2024 7:39 am
Robert Scott
(@robert-scott)
Utenti
In PrusaSlicer, to minimize stringing, consider boosting the print speed and utilizing the retraction feature. These options can be adjusted under "Filament Settings" within PrusaSlicer. Retraction pulls back the filament before each move, helping prevent unwanted strings between print locations. Adjusting these settings can enhance print quality by reducing stringing issues .
Postato : 19/07/2024 4:30 am
