Scaling Down
Papa John
(@papa-john)
Scaling Down
  Hello I am new to this. I am trying to take a 3D file that is two big width wise. When I scale down all 3 axis its changes the bolt holes out of alignment.  What do I do to change the sign without distorting the holes on the item?  Please help  Thanks John
Respondido : 13/12/2021 9:51 pm
sylviatrilling
(@sylviatrilling)
RE: Scaling Down
Are the bolt holes threaded or simple cylinders? If they are simple cylinders, you can right click on the object, select add negative volume, add a negative space cylinder and size as you please. The negative space volume will cut a hole in your object. Repeat for each hole that you need.
Mk3S+,SL1S
Respondido : 13/12/2021 10:59 pm
sylviatrilling
(@sylviatrilling)
RE: Scaling Down
Also, small holes tend to shrink in diameter in the printing process, so make them a bit bigger than you need them to be.
Mk3S+,SL1S
Respondido : 13/12/2021 11:08 pm
RE: Scaling Down
Without actually seeing your model it's hard to offer anything besides wild guess and stabs in the dark...
Respondido : 13/12/2021 11:24 pm
Swiss_Cheese
(@swiss_cheese)
RE: Scaling Down
@papa-john
Can you provide a Zipped up .3mf project file, exported from PrusaSlicer? I will take a look and see if I can help.
Note: the .3mf file must be Zipped up in order to post it here on the forums file server.
Regards
Swiss_Cheese
P.S. I work for PIZZA 🍕
The Filament Whisperer
Respondido : 14/12/2021 3:42 am
RE: Scaling Down
Good one!
Respondido : 14/12/2021 11:28 am
1 les gusta
