Printing with ASA or ABS
towlerg
(@towlerg)
My Sovol and I have been happily printing Prusament PETG for a few months, I started to get an issue with what I assume is a partial blockage (whole or part of a layer will be empty and the finished part breaks easily along the visible void). In the short term I tried reducing speed (a lot) and that seemed to work for a while. Eventually I bit the bullet and replaced the nozzle and that seemed to resolve the problem for PETG.
Unfortunately when I tried PrusamentASA and Prusa ABS the blocked nozzle symptoms came back with a vengeance. The first layer when down (eventually) nicely but after layer 10ish it would stop extruding plastic for a layer or so then continue. I created a deal slow profile (50%) but that didn't seem to help.
My printer has what appears to be an E3D V6 clone, temperature is firmware limited to 260C. It came stock with a 0.4 nozzle. I have no reliable way to check that the nozzle is actually at the temperature it is reporting. I'm using the Prusa filament temperature settings - PETG 240/85 and 250/90    ASA 260/105 and 260/110    ABS 260/100 and 260/110.
My current flail in the dark guess is that nozzle temp is too low.
Is it unreasonable to assume that a larger nozzle would be less likely to clog?
Any advise would be welcome. I can take pictures if that will help.
Napsal : 13/09/2020 11:36 am
gorilerman
(@gorilerman)
RE: Printing with ASA or ABS
Try removing the extruder gear and pushing the filament directly by hand.
If the filament is fed lightly, I think the nozzle temperature is correct.
Napsal : 14/09/2020 10:48 pm
towlerg
(@towlerg)
@gorilerman
Hi, thanks for the suggestion but it appears I have not resolved my cloging problem even for PETG, so it looks like apperent problems with ASA and ABS is just a symptom of my overall problem. Soon as I can I'll post some pics.
Does anybody know if a 0.6m nozzle would be less likely to clog?
This post was modified před 6 years 2 times by towlerg
Napsal : 15/09/2020 7:10 pm
gorilerman
(@gorilerman)
RE: RE:ASAまたはABSを使用した印刷
@towlerg
Hello, towlerg
Are all nozzle throats metal? Or does it contain a PTFE tube?
PTFE is not suitable for use above 240 °. It softens and clogs the nozzle.
We recommend upgrading to eliminate problems around the nozzle.
I used Volcano to reduce troubles around the nozzle.
Napsal : 15/09/2020 11:28 pm
towlerg
(@towlerg)
@gorilerman
Hi, I have the stock Sovol hotend which is a E3D V6 clone. In common with a real V6 there is a short piece of PTFE tube which acts a a guide between the top (the cool end) of the heatbreak and the extruder gears.
Napsal : 18/09/2020 6:31 pm
gorilerman
(@gorilerman)
@towlerg
Hello.
 https://www.youtube.com/watch?v=h2w0Hb4suWs
It comes out from 3:57 in the above video
It refers to the PTFE inside the nozzle throat.
Napsal : 18/09/2020 11:11 pm
towlerg
(@towlerg)
@gorilerman
The video you linked to is for an Artillery X1 which appears to have a V6 Lite clone hotend.
Napsal : 19/09/2020 12:50 pm
