PETG permanently adhered to textured PEI sheet?
gct
 gct
(@gct)
Has anyone run into this failure mode before?  I was printing an octagonal first layer to dial in my z offset and I came back to what looked like a bubble underneath.  I thought it hadn't stuck to the sheet but it's just the opposite, the PETG completely fused with the plate in that spot.    Already ordered a new one because it ain't coming off.  Curious if anyone else has run into this since my Googling didn't seem to indicate it was a problem:
Respondido : 08/05/2022 1:26 am
RE: PETG permanently adhered to textured PEI sheet?
try dribbling IPA around the patch, let it soak a while, then try gently removing the patch again.
Respondido : 08/05/2022 10:55 pm
gct
 gct
(@gct)
This actually helped a bit! I was able to get more of a chunk off but there's still some debris around the edges.  Probably still a goner bit it did help get some up.
Respondido : 09/05/2022 4:16 am
try putting the build placte in the freezer for 5 minutes, and try removing again. if it still doesn't release, offset a small test print so it doesn't clash with the patch, , then print the test print, hopefully the blob will not interfere with Mesh bed levelling, a
and when you finish the test print let the build plate cool naturally, then try removing with IPA again.
Respondido : 09/05/2022 3:15 pm
gct
 gct
(@gct)
I'll give that a shot, do you have any idea why this happens?  PEI coating breaking down maybe?
Respondido : 09/05/2022 3:18 pm
too much adhesion... perhaps...
https://blog.prusa3d.com/how-to-print-on-a-powder-coated-sheet_30178/
Regards Joan
Respondido : 09/05/2022 3:59 pm
