Ironing Print after Complete
TL
 TL
(@tl)
Hey!
Question:
Would someone be able to walk me through how one could re-start a print but only to iron the top layer?
Scenario:
I have a completed and successful print where I incidentally forgot to ensure the topmost layer had ironing enabled so I'm wondering if there's an easy way to essentially "re-start" the print at the last layer (in this case Z8) to iron it.
I had intentionally complicated the model a bit by adding a modifier to enable ironing on all other surfaces except the base black layer to save time, however, I wrongly determined that the modifier covered all of the top layers and only discovered afterwards that it was just a tad too short lol.
Honestly, my girlfriend will think its great either way but it's one of those scenarios where you just know you could have done better haha.
Look forward to any guidance and tips for next time this may happen!
Thanks!
Trent
Veröffentlicht : 08/04/2021 12:58 am
RedDawg
(@reddawg)
RE: Ironing Print after Complete
You could TRY under the Printer Settings tab, Z offset, putting in the Z value of your top layer, BUT, I'd assign a relatively low chance of success. You'd need some method of adhering the finished print to the bed, which would likely raise it a bit, PLUS the finished Z height is (now) likely different from the freshly printed height due to cooling shrinkage (If you're extremely lucky, those two factors would cancel each other), PLUS you'd need to position it precisely in the X and Y directions. Best to just reprint with the correct parameters. Good luck, and let us know!
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Veröffentlicht : 08/04/2021 1:56 pm
TL
 TL
(@tl)
@reddawg
Thanks for the reply! That would be an interesting experiment! I might try it on a smaller piece just to see if it would work. My thought was to try this immediately after the print finished so the bed was still warm and adhering to the print so it wouldn’t need any additional adhesive.
The print turned out okay though...at a distance it’s hard to even tell that the top layer wasn't ironed. Although it’s easy to see the under extrusion during ironing (looking at you Azure Blue).
Veröffentlicht : 08/04/2021 10:00 pm
