Infill density to understand
dan
 dan
(@dan-9)
Hi I am a student working with a Prusa for a project. I need help to understand better the infill density.
Basically I have to compare gyroid infill with honeycomb infill. I have 3D printed with Prusa and Prusaslicer several specimens, only infill, no walls. If for example I use 15% infill for honeycomb I have a mass of 4.8g, while with 15% for gyroid I have a mass of 3.4g. To get 4.8g for gyroid I need 20.6% infill density. I need the same mass to do comparisons.
Do you know what parameter the infill density in prusaslicer refers to? Do you know what is the relationship between infill density and the cell size for honeycomb and gyroid?
Thank you very much
Veröffentlicht : 26/01/2021 8:52 pm
John
 John
(@john-6)
RE: Infill density to understand
I believe honeycomb puts an edging ring around the fill where as gyroid doesnt. This might be why the weights are different.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Veröffentlicht : 26/01/2021 9:42 pm
Mitglied
Read this and look at the pictures.
Veröffentlicht : 27/01/2021 12:42 am
markophillips
(@markophillips)
I would recommend to read 3d printing guide covered by Reviewsed.
Noustra.com
Veröffentlicht : 27/01/2021 10:54 am
Mitglied
@john-13
Sorry, I forgot the link: https://all3dp.com/2/infill-3d-printing-what-it-means-and-how-to-use-it/
Veröffentlicht : 27/01/2021 11:35 am
dan
 dan
(@dan-9)
@cwbullet
Thank you for the link, I knew already the article but the meaning of the infill density is not explained. It is written: "Infill density is the fullness of the inside of a part." What does it mean? It is not related to the weight (or volume) otherwise 15% for honeycomb and gyroid should weight the same for my samples. Maybe each infill pattern has its own rule for infill density and they are not comparable?
Veröffentlicht : 27/01/2021 5:00 pm
dan
 dan
(@dan-9)
@markophillips
Thank you for the link but the infill density is not mentioned
Veröffentlicht : 27/01/2021 5:01 pm
Mitglied
Another link: https://blog.prusaprinters.org/everything-you-need-to-know-about-infills_43579/
This is from Prusa!
Veröffentlicht : 27/01/2021 5:51 pm
Kaithlyn
(@kaithlyn)
Posted by: @markophillips
I have already using 3D printer snapmaker, tho I'm using it just for fun but I can see it is a future.
Veröffentlicht : 09/02/2021 2:41 pm
