Fiberlogy Easy PETG
octal
(@octal)
Fiberlogy Easy PETG
I'm trying to use Fiberlogy Easy PETG on my MK3S. I tried to use the Fiberlogy Easy PETG profile provided with PrusaSlicer. I'm getting a huge amount of stringing (I dried the filament).
I tried to raise the retractation to 6mm, results get better but I'm getting a lof of under-extrusions.
Do you have a working profile for it please?
thx
Napsal : 27/11/2022 8:02 pm
RE: Fiberlogy Easy PETG
I believe 6mm retrction is MASSIVE... I usually use 0.4mm which is half of the default for PETG.
I suspect you are seeing  excess stringing.
have you tried reducing the nozzle temperature to tame the stringing, instead of ramping up the retraction.
On a direct extruder, large retractions take hot filament up into the  heatbreak cold section, which can cause heat creep and poor extrusion.
regards joan
Napsal : 27/11/2022 9:01 pm
1 lidem se líbí
octal
(@octal)
Thank you very much for your message.
I have done a lot of tests, and I tried two different rolls (and colors) from Fiberlogy Easy PETG. Both rolls are new, sealed, I opened them yesturday.
The only way to get descent print with almost no stringing was to set the retraction to 1mm and to lower nozzle temperature as low as 205°C. At this very low temperature the printed part is still very strong. I'm estonished, I use daily various PETG brands (mainly Prusament, but I use also eSun, Sunlu, G3D, ...) and I never had to lower print temperature this low. The lowest temp I used with PETG was arround 230°C (I usely print arround 240°).
I don't unerstand this filament. I'll try to put both rolls again in the food dryer for 8 or 10 hours and will do my tests again.
Napsal : 28/11/2022 7:13 am
I had one roll of PLA that was extremely stringy, and I had to lower the nozzle temperature to 170C to get good prints....
Odd things sometimes happen...
best wishes,
Joan
Napsal : 28/11/2022 9:43 am
1 lidem se líbí
