Designers and engineers: Here are the precise dimensions of screw holes and nut pockets
tdk408
(@tdk408)
These are the exact M3 screw and nut dimensions from Prusa engineers. You can use these when you model your parts that need to be screwed together.
  • through hole is 3.286 mm (the screw and threads pass through)
  • hole with self-cutting threads is 2.791 mm
  • square nut pocket is 5.600 mm x 2.150 mm
  • hex nut pocket is 5.456 mm across the flats
All dimensions were measured Prusa-designed parts, exact to a thousandth of  millimeter. I figure that Prusa engineers are smarter than me, so why should I guess?
(I posted these elsewhere 7 months ago, and I have come back many times to get these specs for my designs. I hope they are valuable to designers of precision parts. 🙂 )
Tom
Napsal : 25/06/2025 4:44 pm
7 lidem se líbí
tdk408
(@tdk408)
RE: Designers and engineers: Here are the precise dimensions of screw holes and nut pockets
I forgot to add, hex nut pockets are 2.4mm deep.
I use these measurements frequently when I add M3 screws and nuts to my models.
These measurements, precise to a micron, come directly from Prusa models.  Needless to say, parts made with this measurements work great.
Tom
Napsal : 03/10/2025 8:39 pm
1 lidem se líbí
