Custom Toolpath
Renan Teuman
(@renan-teuman)
Custom Toolpath
Hello All,
I was wondering if there is a way to manually design the Infill structure, the walls and the horizontal solid layers separately, instead of the slicer taking a solid box and generating these different layers automatically. I generally exp0rt ge0metry from Rhinoceros. Perhaps there there are ways to customize the toolpath. For example, I could have curves on separate layers for infill, walls and floors, and it translates in different speeds for the Gcode. Thank you all in advance.
R
Postato : 03/06/2022 2:31 am
Renan Teuman
(@renan-teuman)
RE: Custom Toolpath
The feature type layers you see on the upper left of this image is what I want to have full control of. I would like to design the infill layers for example.
Postato : 05/06/2022 2:09 pm
Simply incorporate the internal structure in your original design and then slice with 0% infill
Postato : 05/06/2022 4:29 pm
Renan Teuman
(@renan-teuman)
RE: Custom Toolpath
Thank you! That works but I would also like to have that in a separate layer to print it in a different speed, at the moment the interior structure is also treated as an exterior perimeter.
Postato : 05/06/2022 6:39 pm
In a simple shape like your examples above a simple modifier would allow you to make those changes.
Postato : 06/06/2022 4:05 pm
1 persone hanno apprezzato
